It is currently Thu Aug 21, 2025 6:47 am
 Post subject: Rosette Thickness
PostPosted: Fri Jan 31, 2014 11:51 am
First name: EddieLee
Last Name: Brown
How thick do you make your rosettes for a steel string guitar. I am planning one that is 0.075" thick. Is that a good thickness?
_____________
EddieLee
 Post subject: Re: Rosette Thickness
PostPosted: Fri Jan 31, 2014 12:07 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
I make mine about 3/4 thickness of the soundboard and rout the slot a little shallower so it can be sanded flush.
PostPosted: Fri Jan 31, 2014 1:28 pm
Last Name: Kincheloe
I usually go for about 3/4 the thickness of the top when I have the option. But I've done veneer thin, and just short of top thickness, and you could even do entirely through the top, if you add a reinforcement patch inside.
The functional role of the rosette is to seal the endgrain of the top from rapid moisture loss, so thicker is generally better for that. But it's not an essential part. A lot of builders these days use segmented rosettes that don't cross all of the grain lines anyway.
PostPosted: Fri Jan 31, 2014 1:33 pm
I'm not sure I believe the rosettes purpose is to seal end grain. I see it as more of a crack preventer by adding reinforcement structurally, as well as a harder wood preventing pick wear through the spruce. I go about 60% through the board. Then level and clean with the drum sander. As soon as the surface is nice and clean, I flip the board and take to final thickness from the non rosette side.
PostPosted: Fri Jan 31, 2014 1:48 pm
50 to 60% of top thickness for me.
PostPosted: Fri Jan 31, 2014 6:11 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
thinnest i made was a 1 mm veneer.
PostPosted: Fri Jan 31, 2014 8:43 pm
rosettes are more for crack prevention around the sound hole 1/2 depth is about right for me
PostPosted: Fri Jan 31, 2014 8:50 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Half the depth of the soundboard (so about 50 to 60 mil). I use a cross-grained backer on the inside of the soundboard for crack prevention, so I see the rosette purely as an artistic element.
Dave F.
Cambrian Guitars
PostPosted: Sat Feb 01, 2014 12:07 pm
Last Name: Brown
Thanks, That really helps bliss
_____________
EddieLee
PostPosted: Sat Feb 01, 2014 10:36 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I have gotten cheap rosettes that were literally paper thin...
Typhoon Guitars
